Miras
Nov 19, 2016Aspirant
USB drives are loosing configuration after reboot
Hello all, I have two USB drives connected. Once I do configuration of ReadyShare folder path for both of them everything works just fine. But when router reboot or power cycle,then directory path...
- Dec 02, 2016Hi James,
No worry, just figured out! Evolution is unstoppable... DD WRT is on board and drives works as charm!
In any case that upgrade is must have to enjoy that great router we paid for.
Hope thats help to other;)
Miras
Nov 28, 2016Aspirant
Hi James,
I am currently waiting for delivery of new Sweex St032 disk enclosure,with native usb2.0 and I hope it will works as it should!
Btw heave you or any body seen that router wit two sata drives in usb enclosured working properly?
Do you have any idea what to do if same problem occures again?
I will post update after I give it try! Regards Mira
