Miras
Nov 19, 2016Aspirant
USB drives are loosing configuration after reboot
Hello all, I have two USB drives connected. Once I do configuration of ReadyShare folder path for both of them everything works just fine. But when router reboot or power cycle,then directory path...
- Dec 02, 2016Hi James,
No worry, just figured out! Evolution is unstoppable... DD WRT is on board and drives works as charm!
In any case that upgrade is must have to enjoy that great router we paid for.
Hope thats help to other;)
Miras
Nov 29, 2016Aspirant
Hi there,
I am back with my update! and no joy so far:(
https://www.google.com/search?q=sweex%20st032&rct=j
arrived and tested. Drive connnected via USB2.0 sucsessfully..drive assigned with different character(S:\) and I was quite happy and wondered if will be settings persistent after reboot..and what...USB2.0 drive did not connect at all:( USB3.0 drive working just fine and USB2.0 drive with new driver/enclosure is dead until power cycle, seems like usb driver/router has problem to restore connection with hotswap:(
Seems like usb driver in Sweex enclosue is a problem! luckily i can return. so still on the way:(
- JamesGLDec 01, 2016NETGEAR Employee Retired
Hi Miras,
I am not really sure when it comes to enclosure since most of the compatible USD devices for the routers are the usual external drives.
JamesGL
Community Team
