rusty_mahler
Mar 17, 2026Aspirant
USB HD attach to R6900v2
I believe I read (likely in the user manual) that there's a USB port to which I can connect an external HD. What wasn't clear was maximum size for the HD. Also, I was surprised to see the drive ...
Mar 18, 2026Guru - Experienced User
Whats your plan for it? Most local book of face's have used NAS/Servers/older pc's you can stick a ton of hard drives in for better performance and increased options (such as a media server, etc)
- StephenBMar 19, 2026Guru - Experienced User
plemans wrote:
Most have used NAS/Servers/older pc's
I agree that adding a NAS (or sharing a folder on an always-on PC) is a better solution, and would eliminate the need to work around SMB 1.0 and guest access.
