GaryGuertin's avatar
GaryGuertin
Use the Nighthawk R7000 with another Router?
I have been using my Nighthawk R7000 for years with an independent network provider.  I live in a large apartment (3200 sq. ft.) in a Condo.  Last week the Condo Association changed our TV service ov...
  • antinode's avatar
    Apr 04, 2018
    > [...] Is there any way I can use/hook-up the Nighthawk as a slave,
    > booster, etc. to the new modem/router?
       The two usual options would be: 1. Configure your (unspecified) "a
    Comcast Modem/Router" as a modem-only, and use the R7000 as a
    full-function router, or: 2. Configure the R7000 as a wireless access
    point.
       Without an actual model number, I don't know what you can do how with
    your (unspecified) "a Comcast Modem/Router".
       For the R7000 as WAP, visit http://netgear.com/support , put in your
    model number, and look for Documentation.  Get the User Manual.  Look
    for "Use the Router as a Wireless Access Point".
