BladeParker's avatar
BladeParker
Using AC2300 Nighthawk Model#R7000P as wired WiFi extender through Netgear switch (GS308)
From what I understand this should be possible. I want to use the R7000P as a wired WiFi extender with little configuration and as low maintenance as possible. Please clarify my terminology if needed and point the way to some documentation, it would be greatly appreciated.
ISP Router <wired-to> GS308 <wired-to> R7000P
  • I want WiFi coming from my ISP Router
  • I also want WiFi coming from the R7000P (If possible to have the same WiFi connection/name as the ISP, that would be great. Understandable if this requires a second WiFi connection/name)
  • I am not looking for wireless WiFi extender solutions, only wired
  • If the R7000P needs to be directly wired to the ISP Router, that is an option although not prefered
  • If the R7000P cannot do this, please recommend another Netgear solution
Router: https://www.netgear.com/home/products/networking/wifi-routers/R7000P.aspx
Switch: https://www.netgear.com/support/product/GS308.aspx
Thank you.
  • > [...] I want to use the R7000P as a wired WiFi extender [...]
       The phrase is "wireless access point".
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Look for "Use the Router as a
    WiFi Access Point".
       The network switch should be harmless.
    > o I also want WiFi coming from the R7000P (If possible to have the
    > same WiFi connection/name as the ISP, that would be great. [...]
       I'd run the experiment.
    WiFi Access Point".
