GirffyB's avatar
GirffyB
Using cable modem/router combo only as modem
I'd like to know how to run my existing modem/router (C6250|AC1600) only as a modem and use a separate router (Nighthawk AX6 AX4300 RAX45). Is there a way to do this?
  • Yes, you should be able to find a router mode option on the modems web page, should be under Advanced Tab/Adanced Settings
    Router mode may say Yes and No. Select No.
    May find a Bridge mode option here as well.
    Reivew the online user manual for this model modem for this information if you can find it.
  • FURRYe38's avatar
    • GirffyB's avatar
      GirffyB
      Ok, I saw that page when I was looking, but didn't think it could be that simple. Go figure. Thanks for the help.
