hbk_seanmichael
Dec 14, 2018Aspirant
Using r7000p in AP mode any benefits to enabling VLAN for it?
I have my r7000 as mymain router hooked up to my fiber ONT from the ISP. I dont have wifi on that router I just have 4 ethernet wall outlets hooked up to it which lead to my xbox one, a pc, a roku a...
- Dec 14, 2018
11 hour old post pushed to the 2nd page where no one would see it so yes it deserved a bump... you **bleep**ing condescending **bleep**got.
hbk_seanmichael
bump anyone
antinode
Dec 14, 2018Guru
> 1. Enabling VLAN from the r7000 for the port that the R7000P is
> running on.
What would you expect that to do for you?
> 2. Turning DHCP off on the main router (r7000)
How would disabling your only DHCP server help?
> 3. Having the R7000P setup in router mode not AP Mode and let it to
> the DHCP handling
What about the outer router (R7000)? Would that still be a router?
Do you want to cascade multiple routers, with all the problems which
that can cause?
I don't know exactly how your wiring is arranged, but if your
distribution hub is near the ONT, then that would seem to be the best
place for your (only) router. If you want to have a wireless access
point elsewhere, then do that.
Your current arrangement seems about optimal to me. You seem poised
to screw it up. What about it bothers you?
> bump anyone
Is the (free) service here not speedy enough for you?
- hbk_seanmichaelDec 14, 2018Aspirant
- antinodeDec 14, 2018Guru
> 11 hour old post [...]
Not everyone is in your time zone.
> [...] pushed to the 2nd page where no one would see it [...]
This must be some new meaning for "no one". Did _you_ lose track of
it?
> [...] so yes it deserved a bump... [...]
You're welcome. And you expect that marking it as "Solved" will
encourage the kind of attention you want? On the bright side, you now
have "1 Accepted Solution" (and a badge to prove it). Nice work!
Please don't feel any need to answer my questions.
