Rafjel's avatar
Rafjel
Using ReadyCLOUD only to access files on a USB connected memory stick
For the moment my Nighthawk Model R7000 is configured only as an Access Point. When I configure also ReadyCLOUD to access an USB stick that is connected with the R7000, I can see via the web http://r...
  • Rafjel's avatar
    Rafjel
    Jun 26, 2021
    Meanwhile I 've downloaded and installed the latest firmware manually without any problems. I also changed to Router mode instead of Acces Point, and reset to the initial settings. And yes, I can see now via ReadyCLOUD the usb storage WITH its shares!
    Thanks everybody for your help!
