SimonN
Aug 14, 2016Aspirant
V1.0.7.2_1.1.93 has more than halved my speed
Hi All, I knew I shouldn't have...... I updated the firmware. I knew it was a mistake. I'm on FTTH Yesterday it was 204 down / 20 up Today it's waivering between 45-80 down and 20 up....
- Aug 14, 2016
LOL - I apologise for the 'live update' feel to this thread - I've just reconnected the r7000 and tried again - now it's back to normal - I suspect my ISP 'likes' to see their router or something similar. Sorry for the (now) fairly pointless posts.
SimonN
coolguy949
Aug 14, 2016Apprentice
Did you load a saved config? Try setting it up again from scratch on the new FW. I had a similar issue with my R7800 where restoring the config on a newer FW caused slow link speeds. It's possible something changed in the firmware where an old setting is detrimental to performance. I have my previous R7000 at my parents house running 1.0.5.70 with no issues at all and no need to risk the upgrade. Good luck!
