NRF
Oct 05, 2016Aspirant
Verison 3G MiFi connectivity
Can a Verizon 2200 3G MiFi be connected to a Netgear Nighthawk AC 1900 - Model R7000 using a USB to Ethernet adapter cable into the ethernet internet input port? I use both Windows XP and Windows 7 o...
- Oct 06, 2016
Hi NRF,
The R7000 does not support that type of connection. If your 3G MiFi is using a MicroSim card, you might try checking the R7100LG.
https://www.netgear.com/support/product/R7100LG.aspx?cid=wmt_netgear_organic
JamesGL
Community Team
JamesGL
Oct 09, 2016NETGEAR Employee Retired
Hi NRF,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
