wgblondel's avatar
wgblondel
Very poor WiFi performance since 1.0.7.6 update
Hi,
Since I updated to 1.0.7.6 FW, the signal quality is very bad.
2.4Ghz, RSSI : -68
5Ghz, RSSI: -50
I'm at about 7 meters from the router.
The weird thing is that the signal quality of the 5Ghz network is better than the signal quality of the 2.4Ghz network.
What should I do ?
Thanks
  • JamesGL's avatar
    JamesGL
    Jan 22, 2017
    Hi wgblondel,
    Try changing the channels of your wireless network.
  • As suggested in the Netgear Release Notes, did you reset the router to factory default after the firmware upgrade?
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi wgblondel,
