mtlviya
Jun 24, 2017Tutor
VoIP phone cannot initiate outgoing call with R7000 Router Installed
I have had my Nighthawk R7000 Router installed and set up, it works fine except my SIP-based VoIP phone cannot make any outgoing calls anymore (it can still receive calls properly). The error code I ...
- Jul 19, 2017
Hi mtlviya,
Set the VoIP's IP in DMZ mode.
TheEther
Jun 25, 2017Guru
This is just a shot but try playing around with the SIP ALG toggle in WAN Setup.
mtlviya
Jun 25, 2017Tutor
After disabling SIP ALG in WAN setup, it works now. Thanks for your help.
- mtlviyaJul 11, 2017Tutor
After selecting the "Disable SIP ALG" option in the WAN setting, the outgoing calls from VoIP phone works. But the incoming calls to VoIP phone only partially work, it only works right after the VoIP phone generates an outgoing call; after 5 minutes, the VoIP call is not reachable anymore. Any call to this VoIP phone will get an announcement "The subscriber you are calling is not available". Are there any other settings I need to adjust?
- JamesGLJul 16, 2017NETGEAR Employee Retired
Hi mtlviya,
Check this firmware version of the router.
https://kb.netgear.com/000039940/R7000-Firmware-Version-1-0-9-6
- mtlviyaJul 18, 2017Tutor
Hi JamesGL,
The firmware I have is exact the "Firmware Version V1.0.9.6_1.2.19".
I encountered this problem on this version of this firmware.
