mtlviya
Jun 24, 2017Tutor
VoIP phone cannot initiate outgoing call with R7000 Router Installed
I have had my Nighthawk R7000 Router installed and set up, it works fine except my SIP-based VoIP phone cannot make any outgoing calls anymore (it can still receive calls properly). The error code I ...
- Jul 19, 2017
Hi mtlviya,
Set the VoIP's IP in DMZ mode.
JamesGL
Jul 16, 2017NETGEAR Employee Retired
Hi mtlviya,
Check this firmware version of the router.
https://kb.netgear.com/000039940/R7000-Firmware-Version-1-0-9-6
JamesGL
Jul 19, 2017NETGEAR Employee Retired
Hi mtlviya,
- JamesGLJul 23, 2017NETGEAR Employee Retired
Hi mtlviya,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- mtlviyaJul 23, 2017Tutor
Hi JamesGL,
Thanks for your prompt help.
After configuring the VoIP phone as the Default DMZ Server, both the incoming calls to the VoIP phone and outgoing calls from the VoIP phone work now.
I will do more tests in the several upcoming days to see if it keeps working and if it works in other scenarios, I will have the results posted.
According to the R7000 User Manual (May of 2017), page 119, as below.
"DMZ servers pose a security risk. A computer designated as the default DMZ server loses much of the protection of the firewall and is exposed to exploits from the Internet. If compromised, the DMZ server computer can be used to attack other computers on your network"
Since what I have exposed is just a VoIP phone, I guess the risk is very limited, right?
Thanks again for your help.
- JamesGLJul 26, 2017NETGEAR Employee Retired
Hi mtlviya,
Yes that is correct since this is not a computer that can be used to access local devices.
