c7c4c7
Nov 14, 2018Aspirant
VPN Certificate errors
I have a nighthawk r7000p and am trying to implement a VPN, the Firmware Version is
V1.3.1.44_10.1.23 . I've gotten past several easy error but am having problems authenticating using certificates. The error that I am receiving is
Tue Nov 13 13:45:34 2018 us=360087 Certificate does not have key usage extension
Tue Nov 13 13:45:34 2018 us=360087 VERIFY KU ERROR
Tue Nov 13 13:45:34 2018 us=361086 OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
Tue Nov 13 13:45:34 2018 us=361086 TLS_ERROR: BIO read tls_read_plaintext error
Tue Nov 13 13:45:34 2018 us=361086 TLS Error: TLS object -> incoming plaintext read error
Tue Nov 13 13:45:34 2018 us=361086 TLS Error: TLS handshake failed
I have doenloaded the OpenVpn Client, for Windows, via the link supplied, I have included the configuration file
Help would be greatly appreciated
There was an extra line in the config file
I had an extra line in the config file
remote-cert-tls server
Removed it and the connection was established
1 Reply
- c7c4c7Aspirant
