lightbulbstamps
Dec 07, 2016Aspirant
VPN controlling access
I have just got a R7000 router and i am wanting to use the openVPN on it.
My main worry is security as it just seems to generate one set of files with no user name or password support for each user.
I was wondering, if I use "Configuring Access Control on Nighthawk Wi-Fi Router" to allow only known MAC addresses to access my network, would that also be true when using the VPN, such that if the MAC address was not in the "access control table" it would'nt allow VPN access even although the user had the files.
Its just that if anyone ever got access to the files i would have to turn off the VPN feature as they are same files. So I'm hoping that this will be a possible solution to my dilema, using "Access control" features.
Hope it makes sense and someone has come across this problem before.
Thanks ElaineM,
I am a lot happier at using the VPN now, that i can restrict a user from accessing my network throught the VPN unless their MAC address is set to allowed.
- ElaineMNETGEAR Employee Retired
Welcome to the community, lightbulbstamps
It's true, there's no way to get Internet access if you have Access Control turned on unless you input the MAC Address of the computer/s under Allowed list.
- lightbulbstampsAspirant
Thanks ElaineM,
You're welcome.
Have a great day!
