CTam
Oct 31, 2017Aspirant
VPN For AC1900/R7000 open protocols for L2TP
Is there an option to enable AH and ESP protocol if I wanted to setup a local VPN on my computer?
Hi CTam,
NETGEAR router is just a VPN passthrough. You may need to check with the software of the VPN that you are going to use for its configuration.
