wathaifi
Sep 12, 2017Aspirant
VPN on Nighthawk R6700 . What is OPEN VPN? hows that different from my VPN
Can anyone explain please how is openVPN diffrent from the VPN service im subscribed to now? Private Internet Access? I'm also aunable to acces OpenVPN website because its blocked here, how can i ge...
- Oct 08, 2017
Hi wathaifi,
For the OpenVPN, this is not possible. I am not sure with other 3rd party VPN since most VPNs needs a software to install.
JamesGL
Sep 28, 2017NETGEAR Employee Retired
Hi wathaifi,
If the devices that you want to connect to the internet via VPN are connected to the NETGEAR router, then OpenVPN does not work that way. The OpenVPN is applicable if your device is in remote area and is not connected to the R6700 router. It needs a software as well for it to work which the Vonage phone will not be able to connect through VPN.
wathaifi
Sep 28, 2017Aspirant
Thanks James. So there is no solution to this problem? I have a Smart TV, Vonage & a Roku , they are all connected to my home network. Does your answer mean that there is nothing that I can do to setup VPN using this router so that they are all connected to the internet through VPN ?
- JamesGLOct 08, 2017NETGEAR Employee Retired
Hi wathaifi,
- JamesGLOct 12, 2017NETGEAR Employee Retired
Hi wathaifi,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
