Smokie365
Sep 20, 2016Tutor
VPN setup
I'm sorry if this has already been asked but I am having huge trouble with virgin media YouTube and Netflix buffering, can I set up a vpn on my Nighthawk router so that everything on my network goes t...
- Sep 22, 2016
Hi Smokie365,
That is correct. The router can only be set as the VPN server via the OpenVPN and passthrough if using other VPN service but will be able to do configuration as a client.
JamesGL
Community Team
JamesGL
Sep 21, 2016NETGEAR Employee Retired
Hi Smokie365,
The router can serve as the VPN server via the OpenVPN but it cannot be set as the VPN client. If you have other VPN server then the router can be a VPN passthrough.
JamesGL
Community Team
