JacquieMz's avatar
JacquieMz
VPN to access remote LAN without using Remote Desktop
I am looking to add mobile access to my LAN network thru WIFI.  I already can access thru remote desktop to computers running Win 7 Pro, but I need to be able to remotely access the "server" as if the computer is ethernet wired to the LAN, but running thru wifi for access away from the building.  Is this setup even possible?  Everything I have found seems to point to remote access, where you have to have access to a computer hard wired directly into the LAN.  Anyone out there set anything like this up and accessed your LAN directly thru the wifi with a tablet PC on wifi?
Thanks
Jackie
  • JamesGL's avatar
    JamesGL
    Jan 18, 2017
    Hi JacquieMz,
    The scenario you wanted may not be supported by the OpenVPN feature of the router. You may need to follow the suggestion of your software provider.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi JacquieMz,
    1. What is the model number of your router?
    2. The only VPN that NETGEAR supports is the OpenVPN. For other VPN service, you may check 3rd party softwares.
    • JacquieMz's avatar
      JacquieMz
      I currently have a Netgear FVS318G attached directly to my modem from Comcast configured with VPN connections, and then have multiple switches and Netgear Wifi routers on the network.  The Nighthawk AC900 R7000 Smart Wifi router is the one I am using for the remote access currently, I have set up a VPN connection and am tapping into a desktop computer running Win 7 Pro on the LAN.
      My software provider is suggesting I purchase their "host box" and it has terminal service software for as many remote access logins that I need for my remote access for my employees, but I was trying to see if there was a way to do it with my current hardware configurations.  I have 10 computers on my LAN, all connected to a dedicated "server" (Win 7 Pro mapped network drive) running the program they need to access and currently the employees have to come in from the yard or shop to punch in or do their write ups.  I am looking for a way for them to all have their own tablet PC at their work stations and not have to keep coming in to do their reports.
      So basically the question is can you tap into a LAN (wired) from a WIFI connection without going thru a host computer with remote desktop?
      • JamesGL's avatar
        JamesGL
        Hi JacquieMz,
