3v3ntH0riz0n
Jan 31, 2017Apprentice
Vulnerability Summary for CVE-2017-5521
If you purchase this router, flash it to open source firmware, or get the latest update from Netgear ASAP. Another security issue was found with several routers, but older firmware: http://theha...
- Jan 31, 2017
Below is the article that tackles the vulnerability.
Web GUI Password Recovery and Exposure Security Vulnerability
ElaineM
Jan 31, 2017NETGEAR Employee Retired
jeffsilverman
Feb 07, 2017Aspirant
If the firmware installation process describer in Netgear's knowledge base 000036749 is interrupted, then will the router be bricked, or is there a recovery procedure? If there is no recovery procedure, then do the update at a time where, if the procedure fails, you have time to get a new router before you need the internet for something critical. Also, is version 1.0.4.8 the latest version?
Mitre says that this is the latest known vulnerability. www.cve.mitre.org
- StephenBFeb 07, 2017Guru - Experienced User
What router do you have?
There are a couple things you can try, including reinstalling firmware with tftp. I haven't experienced this, so I don't know whe odds of success. If you needed to get a new router ASAP, you'd probably need to buy one.
- jeffsilvermanFeb 07, 2017Aspirant
I have an R6250
As it happens, I am a linux system administrator and I know exactly what a TFTP daemon is, and how to set one. How many people who buy netgear routers, or any other kind of router, know what TFTP is?
- StephenBFeb 08, 2017Guru - Experienced User
I have an R6250
The support page for your router is here: https://www.netgear.com/support/product/R6250
You can check the current firmware, download manuals, etc. You can see that the current firmware is 1.0.4.8.
FWIW I don't work for Netgear, I am just active in the community.
But I'm sure most router owners don't know what TFTP is. What's your point?
