tamme_tekkel
Jan 11, 2018Aspirant
Wait to long ?
Hello If i whant change something for example wifi password en save it. It takes about 1 minnut For this action. In this minut i can do nothing else. My r7000 do not work this way. What ido wrong h...
- Jan 11, 2018Have you update your new NETGEAR?
available4only1
Jan 11, 2018Star
Its take for changing password for my R9000 between 10 and 15 second!! I’m sure you have something not going on!
- tamme_tekkelJan 11, 2018AspirantHello
I buy a netgear router and connect.
Afther connect i change my wifi name and password. Than save.
I try the same by my R7000. Go to fabrik changes. And do the same. This takes 10 a 15 seconds. Why the R9000 not. For example portforwarding is 1,5 minut.
I do not now or this good. Or what i must do?
For the price i thought that i can exspect some quicker than the R7000.
Maybe wrong touhgt?- available4only1Jan 11, 2018StarHave you update your new NETGEAR?
I think there is no update. I do not see at startup a message. I will look tomorrow for this. I am now working. Iwill let you know
- available4only1Jan 11, 2018StarI’m sure there’s no problem with your NETGEAR!!
- tamme_tekkelJan 12, 2018Aspirant
hello
i have looked for update. strange that not write i first screen.
i looked manual and there was a update. now i have installed
V1.0.3.6. now it's much quicker. why before not. i do not know?
i think that now my problem ask before is ok now.
thanks for the information.
