tamme_tekkel
Jan 11, 2018Aspirant
Wait to long ?
Hello If i whant change something for example wifi password en save it. It takes about 1 minnut For this action. In this minut i can do nothing else. My r7000 do not work this way. What ido wrong h...
- Jan 11, 2018Have you update your new NETGEAR?
tamme_tekkel
Hello
I buy a netgear router and connect.
Afther connect i change my wifi name and password. Than save.
I try the same by my R7000. Go to fabrik changes. And do the same. This takes 10 a 15 seconds. Why the R9000 not. For example portforwarding is 1,5 minut.
I do not now or this good. Or what i must do?
For the price i thought that i can exspect some quicker than the R7000.
Maybe wrong touhgt?
Maybe wrong touhgt?
available4only1
Jan 11, 2018Star
I’m sure there’s no problem with your NETGEAR!!
- tamme_tekkelJan 12, 2018Aspirant
hello
i have looked for update. strange that not write i first screen.
i looked manual and there was a update. now i have installed
V1.0.3.6. now it's much quicker. why before not. i do not know?
i think that now my problem ask before is ok now.
thanks for the information.
