LVG
Dec 15, 2017Aspirant
Wall Mount of 1900
I have the 1900 (and the Mesh extender). I need to mount the router on the wall to get it out of the way of my new TV. I've read the document about wall mounting, but the featured router doesn't look...
- Dec 17, 2017
LVG wrote:
I get that I need to screw it on the wall via the crossmark thingies on the bottom of the unit, but I can't figure out (I'm not the handiest woman around) if MY modem should go on its side, upside down or what, and where I should point the antennae.
The design of the mounting holes on my R7000P suggests that you can have the thing either way up, with the LAN ports at the top or on the bottom.
I'd pick the orientation that gives the best access when it is on the wall. If it is high enough then the antennae will cover the area with wifi.
William10a
Dec 16, 2017Master
There are two slits on the buttom for wall mounting the router from what i have seen you will need too make your own temple for where the needed screws are to be.
LVG
Dec 16, 2017Aspirant
Oh, trust me, I will go the princess route and hire a handyman to do the actual screwing into the wall. The issue is HOW to mount it -- like which end is up, for this particular unit (which has been sitting on a table since I got it awhile back but now has to be moved because the Darth Vader antennae are in front of my new, much-larger-than-before TV. No more room on the table, unless you put the router behind the TV, which sucks for range capability. )
- William10aDec 16, 2017Master
The antennas pointing up will work all you need to mount it is a piece of paper and rub it with pen or something too get a outline of the buttom of the router. Now you have a pattern of mount holes and can get a idea where you want it.
Plastic anchers should hold as long you use good ones.
The modem could go almost you can find room the hardest part making the cables and wires look good.
