LVG's avatar
LVG
Wall Mount of 1900
I have the 1900 (and the Mesh extender). I need to mount the router on the wall to get it out of the way of my new TV. I've read the document about wall mounting, but the featured router doesn't look...
  • michaelkenward's avatar
    Dec 17, 2017
    LVG wrote:
    I get that I need to screw it on the wall via the crossmark thingies on the bottom of the unit, but I can't figure out (I'm not the handiest woman around) if MY modem should go on its side, upside down or what, and where I should point the antennae.
    The design of the mounting holes on my R7000P suggests that you can have the thing either way up, with the LAN ports at the top or on the bottom.
    I'd pick the orientation that gives the best access when it is on the wall. If it is high enough then the antennae will cover the area with wifi.
