Logical
Jan 07, 2017Follower
WAN vlan tagging
There are lots of posts on this topic, but I have not found a definitive comment from Netgear. I will just state what I have found relating to the need for a tagged VLAN on the WAN port. We are fib...
- Jan 29, 2017
Hi All,
Check the KB below for the VLAN tagging.
http://kb.netgear.com/25724/VLAN-tagging-setup-for-Nighthawk-router?cid=wmt_netgear_organic
For D6400, the settings are under ADVANCED > SETUP > VLAN/BRIDGE SETUP
Maumentum
Jan 16, 2017Tutor
I just read of someone configuring VLAN on one of there Nighthawk routers, if anyone knows how this was done can you provide me with information about, or means of emailing this person so I can too attempt this config?
Netgear Orbi on Vodafone New Zealand fibre, an they need VLAN enabled, even though I have fibre an I thought I could just plug this into my WAN port and config it right out of the box, I made the mistake of thinking my ONT box was enough to allow a router only to config my new network, this is incorrect becuase of VLAN tagging. Please help me work this out without having to purchase another modem router, as I feel my ISP Huawei doesn't play well with my Orbi, its ok but could be much better.
JamesGL
Jan 29, 2017NETGEAR Employee Retired
Hi All,
