smegleberry
Sep 18, 2016Tutor
Warranty is a Joke
Having problems with 2.4 band of the router its unusable nothing will connect to it ..Factory reset the item several times Called support all they wanted to do is sell me a warranty as its been over ...
- Sep 19, 2016
It's not a silly threat. Netgear has removed the firmwares from the server for all NeoTV products. Unfortunately, Netgear also did not allow one to skip the quick setup. So, by doing so, all NeoTVs factory reset are useless. Solution would be for Netgear to put the files back up, but they won't. Then, as many other have tried contacting Netgear because they believe there's a problem with their device, Netgear tries selling them tech support on a device that they've effectively broken. That's just bad all around. It's not like I'm out a lot of money, but the principle of a company rendering devices useless, and then trying to sell them tech support is more than a little ridiculous. That is the level of customer care I've come to expect from Netgear. So, silly threat? No. I'm telling everyone I know to avoid Netgear. Use Linksys. I can chat with tech support for free, or do a phone call for free within the ENTIRE warranty period. Enough people share that sentiment, and Netgear should start caring...
BTW, I came here because I went to the community, and this was at the top. When I saw the post, I could relate. Due to continued comments, it's staying on the top of the community. Think about that.
smegleberry
Sep 19, 2016Tutor
Just checked out the Linksys EA9500 Max-Stream AC5400 Tri-Band and they have a 3 year warranty including support.and alot of great reviews going to go buy one of these . Tired of dealing with netgear and there support staff ..paying for a warranty when it still under warranty is totally unacceptable .
- michaelkenwardSep 19, 2016Guru - Experienced User
smegleberry wrote:..paying for a warranty when it still under warranty is totally unacceptable .
You don't. That's not how it works.
- microchip8Sep 19, 2016Master
not saying it's a bad product, but you'd be lucky to get a single firmware updated in a year. Linksys is known to drag its feet for a long time,and it got worse after they got aquired by Belkin. Firmware is also very basic on the recent models
