visualsoul's avatar
visualsoul
Follower
Dec 05, 2020
Warzone -- Port Forwarding for Multiple Devices
We are trying to forward ports for both our PC and PS4 to be able to play COD: Warzone. Right now, I'm only able to forward ports for the PS4 and we are able to get an open NAT, but I'm stuck on Strict for the PC. I've tried putting the PC in DMZ (I know, it's not recommended), just to try something else. Is there a way I can make both of these devices work properly or will only one be able to have port forwarding. Seems like there should be a solution available.
  • > We are trying to forward ports for both our PC and PS4 [...]
       _How_, exactly?  Which ports?  To where?
    > [...] I'm only able to forward ports for the PS4 and we are able to
    > get an open NAT, but I'm stuck on Strict for the PC. [...]
       "not able" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       If you're trying to forward some particular set of ports to multiple
    destinations, then I'd guess that you're doomed, because that makes no
    sense.
    > [...] Seems like there should be a solution available.
       Seems as if there should be a better problem description, too.
    • aaronibm21's avatar
      aaronibm21
      Luminary
      Buenas tardes, podrias decirnos que puertos y como lo has echo para configurar el xr500 los puertos del warzone??
      Gracias!!
