nUUK25's avatar
nUUK25
Tutor
Aug 20, 2019
Web Publishing Service on Zuxel NAS326 and Port Forwarding on Netgear Router
Hello,
I am on uncharted waters - I only know how to setup wireless: set password, naming the flag and enable encryption. I have no experince in Port Forwarding and what it does. According to Zyxel NAS support; in order to make the Service: Web Publishing function on my Zyxel NAS326, I need to port forward on the Netgear router: Port no. 5000 must be open and set this up with upd and tcp protocol on the router.
How do I do this ?
Right now, I have access to the files on the shared folder I have web Published, from all the PC which are on the  LAN - The address format which the NAS has created looks like this: http://[server-name:5000]/MyWeb/Public ....where the folder; 'Public' is shared. On that address; files are visible in a browser and they can open and be saved if need be on the LAN. I need them to be accessable for the rest of the world !! If I try the same URL from an 'external' internet based PC, there are no web-page to be seen.
Hope you can help out here  :O)   Lars
  • nUUK25's avatar
    nUUK25
    Sep 06, 2019
    Hello Antinode,
    I just want to thank you for all your help - It has been most pleasant and a great leaner for me.
    Best regards    Lars
  • > [...] I have no experince in Port Forwarding and what it does. [...]
       That will need to change.  Port forwarding is what the router does to
    deal with a message which arrives at its WAN/Internet port from the
    outside world.  Your ISP has assigned one (external) IP address to your
    whole installation; either you or your router has assigned an entirely
    different (LAN) IP address to each device on your LAN.
       If someone in the outside world wants to send a message to a device
    on your LAN, all he can do is send it to your router.  How, then, does
    the router know what to do with that message?  To which of your devices
    (if any) should it forward that message?
       A port-forwarding rule is what tells the router what to do with such
    a message.
    > [...] http://[server-name:5000]/MyWeb/Public [...]
       More precisely:
          http://[server-name]:5000/MyWeb/Public [...]
       Note that your "[server-name]" could also be your external IP
    address instead of a DNS name.
       That "5000" is the relevant port number.  You can think of it as like
    an apartment number after a street address (IP address).  In this case,
    you'd want a port-forwarding rule like:
          Service Type: TCP+UDP
          External port range: 5000
          Internal port range: 5000
          Server IP Address: <LAN_IP_address_of_NAS>
       That implies that the NAS device needs a fixed LAN IP address, which can
    be arranged at ADVANCED > Setup LAN Setup : Address Reservation.
       With such a rule in effect, when a message destined for port 5000
    arrives at your router's WAN/Internet port, the router will forward it
    to the device at <LAN_IP_address_of_NAS>.  When that device sends a
    reply to that message, the router will handle the reply, ensuring that
    it returns to the outside-world device which sent the original message.
       It's important that the IP address of the WAN/Internet on your router
    match your public (external) IP address. If there's another router
    between yours and the Internet (which could be a second router at your
    site, or at your ISP's site) then you can expect problems.
       As you might guess, you could specify different external and internal
    port numbers in your port-forwarding rule.  The external port number is
    what is used in the outside world; the internal port number is what is
    used on your LAN.  So, for example, if you had a second NAS device, you
    could create a rule like:
          External port range: 5001
          Server IP Address: <LAN_IP_address_of_NAS-2>
    Then, a URL like the following would reach "NAS-2":
          http://[server-name]:5001/MyWeb/Public [...]
       On your LAN, NAS-2 would still use port 5000, but, because of that
    port-forwarding rule, it would be seen at port 5001 from the outside
    world.
    • nUUK25's avatar
      nUUK25
      Tutor
      Hello, ...and thanks for the answer; Antinode, which open up some core issues:
      You mention that the IP which my router receives from my ISP should be static and I have a suspision that is not the case !! In general, I check ip with IPCONFIG in CMD. If I unplug the router and plug in a PC on the wall it gets nearly the same ip (except for one digit) as what the router gets. Similarly another PC get another ip, 2 digits away from the router ip which tells me they are all assigned dynamically. The final straw is; if I try to ping the router IP address from a PC which connects to the internet over the mobilenetwork; USB-modem, it states; 'reply from 10.117.15.173: Distination net unreachable' ......Which I interpret; the router do not get a real external IP addresse and it matches the fact that my ISP advertise on their website that I can buy a fixed IP address for a minor one time payment.
      Antinode, am I on the right path, you think ?
      • schumaku's avatar
        schumaku
        nUUK25 wrote:
        ...if I try to ping the router IP address from a PC which connects to the internet over the mobilenetwork; USB-modem, it states; 'reply from 10.117.15.173: Distination net unreachable' ......Which I interpret; the router do not get a real external IP addresse  ...
        If your R7800 does show the same RFC1918 address on the Advanced -> Internet port IP address information, this is correct.
