tommyd5555
Oct 20, 2025Aspirant
Website blocked on RAX-50
Beginning on 10-17-25 I began receiving this message when attempting to access https://www.riil.org/: This IP Address has been blocked. Please contact support if you believe you have received thi...
- Oct 25, 2025
Closing the loop on this: The administrator of the web site was able to remove the block. The issue has been resolved. Thank you, everyone, for your support.
tommyd5555
Oct 21, 2025Aspirant
Hi I am attaching a screenshot of the error I receive when trying to navigate to https://www.riil.org/. Interestingly, the URL changes to riil.org/WebBot.aspx. It does not look like Parental Controls or Armor are installed/setup because when I tap those entries in the Nighthawk app I am prompted to sign up.
Oct 22, 2025Guru - Experienced User
tommyd5555 wrote:Interestingly, the URL changes to riil.org/WebBot.aspx
That URL exists on riil.org, so the block is being done from their web server - not your router.
What happens if you go to the address bar and manually remove the /WebBot/aspx (and then hit return) ? If the problem disappears, then perhaps autocomplete is somehow getting in the way.
As CrimpOn suggests: If it still happens, you should contact the school. They might have blocked your IP for some reason (before it was assigned to you), and never removed the block.
- tommyd5555Oct 22, 2025Aspirant
Same issue if I remove the /WebBot/aspx and attempt to hit the site again. Looks like I'll have to reach out to the Rhode Island Interscholastic League to see why I'm blocked. Thank you.
