newmanv
Feb 20, 2018Guide
What is the Netgear router with most detailed Internet access log?
We want to log all Internet activity. What is the Netgear home router with the most detailed Internet usage / access log? Cheers.
- Feb 21, 2018
Not sure exactly what you mean by "all internet activity". Even to what details of that activity you want?
You might try contacting Netgear Sales, via phone ((408) 907-8000) or e-mail (sales@netgear.com ) and ask them?
The R7000 has these options for instance:
Include in Log Attempted access to allowed sites Attempted access to blocked sites and services Connections to the Web-based interface of this Router Router operation (startup, get time etc) Known DoS attacks and Port Scans Port Forwarding / Port Triggering Wireless access Automatic Internet connection reset Turn off wireless signal by schedule
IrvSp
Feb 21, 2018Master
newmanvwrote:OK.
We need a new router.
We want the new router to be Netgear.
We want to know what Netgear router has the most detailed Internet access / Internet usage log.
Thanks in advance.
No offense meant, but that still doesn't offer a full answer to the question. 'Most detailed' is basically meaningless. To what level? What data?
For instance, here is part of my log from the time it sent me e-mail this morning, and I do NOT have all possible content options checked:
[DHCP IP: (192.168.1.3)] to MAC address 10:AE:60:57:xx:xx, Wednesday, Feb 21,2018 08:27:21
[Admin login] from source 192.168.1.30, Wednesday, Feb 21,2018 08:16:05
[DHCP IP: (192.168.1.40)] to MAC address 08:BD:43:A5:xx:xx, Wednesday, Feb 21,2018 08:02:19
[DHCP IP: (192.168.1.30)] to MAC address F8:B1:56:DD:xx:xx, Wednesday, Feb 21,2018 07:33:58
[Time synchronized with NTP server] Wednesday, Feb 21,2018 07:06:00
[Internet connected] IP address: 67.8.xx.xxx, Wednesday, Feb 21,2018 07:06:00
[email sent to: irv@xxxx.com] Wednesday, Feb 21,2018 07:01:02
Now that isn't a lot of detail, and again, not all possible options are checked.
Sometimes I'll see stuff like this:
[Time synchronized with NTP server] Tuesday, Feb 20,2018 15:34:41 [Internet connected] IP address: 67.8.95.133, Tuesday, Feb 20,2018 15:34:40 [Internet disconnected] Tuesday, Feb 20,2018 15:34:36 [Internet connected] IP address: 192.168.100.20, Tuesday, Feb 20,2018 15:34:19 [Internet connected] IP address: 192.168.100.20, Tuesday, Feb 20,2018 15:34:09 [Internet connected] IP address: 192.168.100.20, Tuesday, Feb 20,2018 15:33:49 [Internet connected] IP address: 192.168.100.20, Tuesday, Feb 20,2018 15:33:38 [Internet connected] IP address: 192.168.100.20, Tuesday, Feb 20,2018 15:33:28 [Internet disconnected] Tuesday, Feb 20,2018 15:32:44
That is my modem re-booting for instance.
Other times I'll see false DOS Attacks...
So not knowing what you are looking for it is a difficult question to answer. For instance, if you are looking for the name of the program using the Internet I don't think you can get that from the router.
newmanv
Feb 21, 2018Guide
Thanks, this helps a lot. Can you please send me a screen shot showing all the possible options?
- IrvSpFeb 21, 2018Master
newmanvwrote:Thanks, this helps a lot. Can you please send me a screen shot showing all the possible options?
That is what I posted above, and it is for the R7000.
That said, again, it doesn't detail the full data you would see, and hence, the question of what you want to see.
The more data that has to be collected can/might interfere with the operation and speed of the router. Generally speaking about all you'll get is the IP and MAC Address of a device doing what is a selected option is and the time, or a lot of the time just specifying the option that you selected, like sending e-mail with limited data pertaining to that option. DOS Attacks will show the IP Address of the attacker and time but nothing else, not even where it was directed.
- michaelkenwardFeb 21, 2018Guru - Experienced User
The easiest way to look into what you can do is to get the manual for one of Netgear's routers and read that.
Most offer the same logging features.
The most widely used router is probably the R7000.
There is a manual for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
Page 151 has a section View Logs of Router Activity.
If you want to compare that with another router, maybe look at the R7800:
>>> R7800 | Product | Support | NETGEAR <<<
See page 94.
I mention these because I have variants of them and have used the logs on both.
IrvSp wrote:The more data that has to be collected can/might interfere with the operation and speed of the router.
This is important. One recent user found that asking the router to log the traffic on their hardware, using the traffic meter, slowed down their internet connection at the router. They disabled the traffic meter and got the speed they expected.
Another cointrol that can slow down access is the QoS feature.
