soaxm1's avatar
soaxm1
Follower
Jun 17, 2017
What is the setting HT160 for?
HI,
I'm new to the Community. I bought a new Netgear and have configured it but there are some setting I'm not familiar with and want to know what these setting do or what they are for. As I come across a setting that I'm not familiar with I will post to see if someone can educate me. If I ask a question about a setting that has been asked before (and I'm sure I will), Please bear with me or direct me to the sticky, link or post where the answers are located.
I will always search the internet first to see if I can find the answer before I come here looking for the answer. 90% of what I have already configured I do understand, it's that 10% that gets me and take up a lot of time searching and trying to understand it. If I'm asking a question here that means that I couldn't find the answer on the Internet or I found the answer but couldn't understand it (what I was reading or hearing).
Thanks in advance for helping me to understand my router and which will help me understand my whole network better and other things I can do with this Beast of a router.
:smileyhappy:
Question:  What is the setting HT160 under the MU-MIMO setting for?
My router model is AD7200 (R9000)
Router Firmware Version V1.0.2.32
  • Retired_Member's avatar
    Retired_Member
    Jul 17, 2017
    According to the help section on the bottom it says "HT160 can improves 11ac WiFi performance" notice the error in gramma, but I can never enable mine, I just think its one of the many problems on this BETA or should I say ALPHA Router people are getting, the list grows every day.
    Regards
    Retired_Member
    Regards
    • ElaineM's avatar
      ElaineM
      NETGEAR Employee Retired
      Enabling this option (HT160) will increase the channel width and speed provided that your wireless clients must also support HT160.
      For the grammar, I have forwarded it to the proper department to have it corrected.
      Thank you!
