NettyJim17's avatar
NettyJim17
When I download the newest firmware, the download is a .ZIP containing, a .CHK, and a HTML file?
My current router version is: 1.3.1.64_10.1.36....but the newer version is, 1.3.2.134.
> ADMINISTRATIVE, FIRMWARE UPDATE, then after downloading the newer firmware to my DOWNLOADS, the ZIP file is nothing more than a .CHK file, and an HTML.
 I opened up my Nighthawk APP, checked firmware updates, then it shows my version, 1.3.1.64_10.1.36, "firmware is up to date."
 Does it matter if my version is a tad lower than the most current version, and according to netgear, my firmware is UP TO DATE?
AND WHY, am I not receiving an actual firmware update file, but instead, receiving fragmented .CHK, and HTML files in my Downloads ?
Thank You!
  • You can update your firmware manually. What do mean by the files are fragmented?
    • NettyJim17's avatar
      NettyJim17
      No1Mportnt  antinode michaelkenward
      Hello Community!
           Whenever I download file, usually it is an executable .exe file, or a .ZIP file, then extract it's contents into a folder on my desktop or into a another folder.
           I hace attached a screen shot of what I see after I download to my Download folder.  When I extract this .zip file, it shows two files. A .chk file, and a .html file.  When I try to open the .chk file, I get the grey box, as you can see.
          I do not think that my Win.7 Pro 64, is causing this, or maybe I do need something.
      So those who think it's easy as downloading, extracting, then, RUN or SAVE this firmware, is not understanding this issue that I am experiencing.
       Maybe I am doing something wrong. Based on my screen shot, stating at the top, in order, is what I have received.
      AM I ONLY SUPPOSED TO GET THESE TWO, .CHK FILE, AND HTML FILES?   IF SO, WHY CAN'T I OPEN AND UPDATE MY FIRMWARE?
      Thank You!
  • > [...] the ZIP file is nothing more than a .CHK file, and an HTML.
       Yup.  And you were expecting what, exactly?
    > version, [...]
       Not to me.
    > [...] and according to netgear, my firmware is UP TO DATE?
       Which part of Netgear do you trust more?
    > [...] WHY, am I not receiving an actual firmware update file, [...]
       What led you to believe that you'd know "an actual firmware update
    file" if you tripped over one?
          https://community.netgear.com/t5/x/x/m-p/1721037#M124018
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Downloads.  (For older versions, under Firmware and
    Software Downloads, look for "View Previous Versions".)  Find the
    kit(s).  Download the kit(s) you want.  Read the "Release Notes" file
    for instructions.  (In the User Manual, look for "firmware", and,
    especially, for a topic like "Manually Upload Firmware to the Router".)
    When that fails because of a deficient User Manual, try:
          https://kb.netgear.com/23960
      NettyJim17
      antinode
          "> [...] the ZIP file is nothing more than a .CHK file, and an HTML."
         "Yup.  And you were expecting what, exactly?"
      ____________________________________________________
       Antinode,
           Well, what I was expecting?  I guess I was expecting to update my firmware.
        Clicking on either the .CHK, or the .HTML does not do anything at all. It does not open up, it does not 'magically,' and automatically, do the update, it does nothing at all.
         So unless, I do not know which method I need to do, to download these two files, then please enlighten me. I have download hundreds of files in my computer-ing history, and this is the first time, I ever ran into this, when I can not open, or do the update.(s)
         Thanks!
      • michaelkenward's avatar
        michaelkenward
        The link I provided took you to the official Netgear KnowledgeBase article on how to manually update the firmware on any device. That's the process that No1Mportnt mentioned.
        The release notes that you can read before you download the zip file should also have similar instructions. No guarantees there because Netgear has a habit of changing things without warning us.
        I decided to keep it simple, without throwing on gratuitous insults or useless details, and because I thought that Netgear's instructions were straightforward. Maybe not. Are you still after help?
        Those .img and .chk extensions can certainly confuse people because they are not unique. The trouble is that there are limits to the number of extensions available. You just have to know that they are not files that you can open or run. In this case, you have to use a browser to "send" the file to your router. It then writes the data into its memory, replacing the old firmware.
        It is actually a pretty straightforward process. One you have done it you will quickly become a pro at firmware updates. It is worth getting familiar with the process because it is more reliable and safer than allowing the router to do its own thing, especially when that involves a wifi connection that can fall over in mid transfer, leaving you with a dead device.
    • antinode's avatar
      antinode
      Guru
      > This might he useful: [...]
         So useful that suggesting it only once wouldn't have been adequate?
         Reading before posting can avoid some wasteful redundancy.  Perhaps
      you should try it from time to time.
