Tehcookiemonsta
Sep 02, 2015Aspirant
Where is the ADSL Line Sync status on R7000
As the Title says, ive got to be missing it even though it seems like ive looked everywhere. i can't find the ADSL line sync page? :smileyfrustrated:
- Sep 02, 2015Are you sure you have a R7000? It doesn't have an ADSL modem. It's a pure router.
You may have a D7000. In that case the ADSL stats should be on the "show statistics" page reachable from the Advanced home page.
Tehcookiemonsta
Sep 03, 2015Aspirant
Just realised, that it can only be seen on the modem, my bad i'm still a noob at networking , although studying.
My Modem router is bridged to my R7000 however i can't view the modem router after bridging it to the R7000. Am i also mean't to enable bridge mode on R7000
rpoffen
Sep 03, 2015Virtuoso
Once in bridged mode, you likely cannot see the modem itself, it is simply a translator for the DSL to ethernet. You must leave your R7000 in router mode though or you will not be able to login to your ISP (which probably uses PPPoE), nor will your clients be able to get an IP address (the R7000 is the DHCP server).
