Tehcookiemonsta
Sep 02, 2015Aspirant
Where is the ADSL Line Sync status on R7000
As the Title says, ive got to be missing it even though it seems like ive looked everywhere. i can't find the ADSL line sync page? :smileyfrustrated:
- Sep 02, 2015Are you sure you have a R7000? It doesn't have an ADSL modem. It's a pure router.
You may have a D7000. In that case the ADSL stats should be on the "show statistics" page reachable from the Advanced home page.
TheEther
Sep 03, 2015Guru
Many modem/router units will continue to have an IP address for management purposes. Often, it will use the same address before bridge mode was enabled. If you remember what it was, then try it.
It may be possible to discover the address using a traceroute. On Windows, open a Command Prompt, and enter "tracert <ipaddress or hostname>". Use any Internet address or website. For example, "tracert netgear.com".
If your modem has an IP address, it will often be displayed as the second hop in the tracert output.
Tehcookiemonsta
Sep 03, 2015Aspirant
Hey , I tried traceroute, however the second IP is defintely not in my network. traced to google.com.au second IP 10.20.23.174 had 18ms
First IP was the R7000 which i know.
- TheEtherSep 03, 2015Guru
10.20.23.174 could very well be your modem's private IP address. Try entering that address into your browser.
- TehcookiemonstaSep 03, 2015Aspirant
I did that...
My Modem was on a Class C network i uset to kno its IP however, the first time when i bridged my R7000 to the modem router i tried to go back to my Modem routers page and it just didn't work. Am i also mean't to enable bridge mode on my R7000's side too?
- TheEtherSep 04, 2015Guru
No. Leave your R7000 configured as a router, especially since your modem/router is in bridge mode.
Can you tell us more about the bridge mode on the modem/router? What is the model of the modem/router?
On some models, bridge mode is more like a glorified DMZ instead of a true bridge mode. That is, one device (e.g. a personal router) is designated to share the modem's public IP address and is given any traffic that is not specifically directed to the modem itself. Any other devices plugged directly into the modem/router would continue to receive IP addresses assigned by the modem/router. So, one thing you can try is plugging a computer directly into the modem/router. If you get a private IP address, then the modem/router is behaving as I described. You should be able to log in by connecting to the default gateway address.
