Tehcookiemonsta
Sep 02, 2015Aspirant
Where is the ADSL Line Sync status on R7000
As the Title says, ive got to be missing it even though it seems like ive looked everywhere. i can't find the ADSL line sync page? :smileyfrustrated:
- Sep 02, 2015Are you sure you have a R7000? It doesn't have an ADSL modem. It's a pure router.
You may have a D7000. In that case the ADSL stats should be on the "show statistics" page reachable from the Advanced home page.
Tehcookiemonsta
Sep 12, 2015Aspirant
Hey, I plugged one of my pcs directly into the Modem and got an ip which worked thank you!
However i tried to get onto this ip without being connected directly to the modem and it didn't work. I am on two different lans right?
TheEther
Sep 12, 2015Guru
Yes, the modem is still maintaining a LAN for directly connected devices and is separate from the LAN behind your router. As I mentioned before, you should insure that your router is using a separate IP subnet than the one maintained by the modem. For example, if the IP address you obtained while plugged in directly to the modem was 192.168.1.X, then you need to reconfigure your router to 192.168.2.1. Once you do this, you should be able to reach the modem from behind the router.
- TehcookiemonstaSep 12, 2015Aspirant
Hello, I changed my Routers IP to the 192.168.2.X network however i still can't reach the modem.
