Tehcookiemonsta
Sep 02, 2015Aspirant
Where is the ADSL Line Sync status on R7000
As the Title says, ive got to be missing it even though it seems like ive looked everywhere. i can't find the ADSL line sync page? :smileyfrustrated:
- Sep 02, 2015Are you sure you have a R7000? It doesn't have an ADSL modem. It's a pure router.
You may have a D7000. In that case the ADSL stats should be on the "show statistics" page reachable from the Advanced home page.
TheEther
Sep 13, 2015Guru
I'm running out of ideas. Does the WAN interface of the R7000 have a 192.168.1.X address? Or does it have a publicly accessible IP address? If it's the former, then bridge mode is not enabled, but you should be as able to log into the modem. If it's the latter, then perhaps the modem cannot pick out traffic destined directly for it (I.e. you can't log into it from a device behind the R7000).
Tehcookiemonsta
Sep 13, 2015Aspirant
Hello Ether, I don't understand what you mean?
- TheEtherSep 13, 2015Guru
When you log into your R7000 and click on the big Internet panel, is the Internet IP Address something like 192.168.1.X or something else? If it's something else, don't post it here or only provide at most the first two numbers.
- TehcookiemonstaSep 13, 2015Aspirant
Oh thats what you mean't, It shows my Public IP address. Not private.
Ok, then I guess you cannot access your modem from behind the router. You will simply have to plug directly into the modem. Or keep Wi-Fi enabled on the modem and join it whenever you want to check the line stats.
