tasumegam
May 02, 2022Follower
Which Netgear Router
I want to buy a router. Wirecutter.com says get the Netgear r7000p. I’ve heard Netgear makes some good stuff, so I checked them out and holy crap do they make a lot of routers that all seem the sam...
May 02, 2022Guru - Experienced User
Do you mind renewed products?
If not, go to amazon and type netgear AX5700 renewed. It device it pulls up is the RAX75 but you won't see the model listed. Its a lot more capable and cheaper than the R7000P. Its a much newer device and even if you buy an aftermarket warranty, you'll still come in under that budget.
I wouldn't recommend the R7000P, I'd go with the R7800 over it or a newer generation AX device.
- microchip8May 02, 2022Master
The R7800 is no longer sold, unless you go refirbished or second hands. I recently bought a RAX43 for 170 euro's and am very pleased with it. Firmware has a few bugs but I can live with it and hopefully NG will iron them out. The RAX43 has been very stable on me, currently with an uptime of 46 days with no issues whatsoever.
