alokeprasad
Nov 30, 2020Mentor
Which way to orient the antennae of the R9000 for lateral beamforming?
I have my R9000 X10 in the front of the house. Thats where the cable outlet and cable modem is. The house isn't wired up for ethernet or coax. So re-positioning the R9000 is not practical at this ti...
Nov 30, 2020Guru - Experienced User
The 5ghz don't usually have an 'auto' function because it isn't as necessary as it was with 2.4ghz. 2.4ghz broadcasts a lot further and through more materials. 5ghz is a bit self limiting in distance. And there's more channels. Also because they're faster, they tend to not be actively broadcasting as much.
alokeprasad
Nov 30, 2020Mentor
So, how does the R9000 decide which channel to use (amongst the many listed, including some tagged as DFS)? Any difference in performance if I select some other channel?
Curious.
Aloke
- plemansNov 30, 2020Guru - Experienced User
Not a whole lot. The lower 5ghz channels used to be limited in broadcast strength but I think that got lifted several years ago.
The best thing to do? download a wireless channel scanner like inssider or arcylic and actually scan your area. Then you can choose a free channel. As well as one like acrylic actually shows the channel overlaps to view.
- alokeprasadNov 30, 2020Mentor
That would be sooo useful. Unfortunately, those are not available on iOS :smileysad:
Thx for your help in this thread.
Aloke
- plemansDec 01, 2020Guru - Experienced User
there are apps for it on mac's.
The Best WiFi Channel Scanner Apps for macOS (netspotapp.com)
