Markg2's avatar
Markg2
Tutor
Sep 12, 2017
White vs. Amber (Orange) Ethernet port status LED
Model R7300DST (AC 1900)
One of the ports blinks Amber/Orange vs. white. Support says, "The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections.".
2 of the 4 machines are Ethernet vs. WiFi. Of those 2, 1 is white and 1 is Amber.
What makes no sense is that I don't have an internet connection that anywhere near supports gigabit speed. So why the amber light?
Mark
  • > I know how to calc internet down/up speed [...]
       More accurately, you know how to run some program which measures it.
    > [...] but how can you determine the speed of data to and from
    > different PC's on the peer to peer network?
       There may be fancy programs available to do this, but I normally just
    transfer a file (which is not trivially small), and measure the time.  I
    typically have an FTP server running everywhere, and binary FTP is a
    pretty low-overhead protocol, so I normally time an FTP transfer.  Many
    FTP client programs have built-in time recording; Wget, for example:
    pro3$ wget ftp://alp-l/tru64/T64V51BB27AS0006.tgz
    --2017-09-12 13:51:01--  ftp://alp-l/tru64/T64V51BB27AS0006.tgz
               => 'T64V51BB27AS0006.tgz'
    Resolving alp-l... 10.0.0.9
    Connecting to alp-l|10.0.0.9|:21... connected.
    Logging in as anonymous ... Logged in!
    ==> SYST ... done.    ==> PWD ... done.
    ==> TYPE I ... done.  ==> CWD (0) tru64 ... done.==> CWD (1) tru64 ... done.
    ==> SIZE T64V51BB27AS0006.tgz ... done.
    ==> PASV ... done.    ==> RETR T64V51BB27AS0006.tgz ... done.
    T64V51BB27AS0006.tg     [                  <=> ] 205.60M  61.5MB/s   in 3.4s
    2017-09-12 13:51:05 (59.7 MB/s) - 'T64V51BB27AS0006.tgz' saved [215586563]
       Note that "59.7 MB/s" would be about 478Mb/s (59.7 MB/s * 8bit/byte).
    Of course, this method may also incur sloth from the file I/O if that's
    slower than the network I/O (which may be true in that test).  A fancy
    program could send dummy data, and discard what it receives, and so get
    a network speed value which is independent of any disk I/O.
       The effort you put into any measurement depends on how much you care
    about the result.  I typically don't care much about such data.
  • > What makes no sense is that I don't have an internet connection that
       No, it makes sense.  A LAN port LED shows the speed of the connection
    between the router and the connected device.  This is independent of the
    speed of your Internet connection (the connection between the router's
    WAN/Internet port and your ISP).
       You may not care, but the devices on your LAN can talk to each other
    as well as to the Internet.  In that case the communication speed would
    depend on the LAN port speed(s), not on the speed of the Internet
    connection.
    • Markg2's avatar
      Markg2
      Tutor
      I do care since I do automated backups between the connected machines.
      Why would one Ethernet port be blinking at 100 Mbps and the other at gigabyte?
      The WiFi is still limited to 100 Mbps?
      Mark
      • antinode's avatar
        antinode
        Guru
        > gigabyte?
           Nowadays, Ethernet port speeds are usually negotiated by the devices
        being connected (when they're first connected).  With my weak psychic
        powers, I have no idea what your devices ("machines") are, nor what
        their Ethernet speed capabilities might be.  (Note, too, "gigabit" v.
        "gigabyte".  It's a factor of eight.)
           If you think that a device has gigabit speed capability but it has
        negotiated a sub-gigabit speed link, then you might try disconnecting
        and reconnecting the cable.  In some computers, the Ethernet interface
        gets its power from the standby source, so it's always on, even when the
        rest of the system is off ("off").  (This allows a Wake-on-LAN feature,
        where a special network command message can switch on the main system
        power.)  The link speed for a gigabit interface in standby mode may be
        only 100MHz.  It should get renegotiated (to gigabit speed?) when the
        main system starts, but that could fail.
           Wireless speeds depend on many factors, including which radio band
        you use (2.4GHz or 5GHz), local signal conditions, interference, and so
        on, plus the intrinsic speed limits of the hardware.  From a router
        which is advertised as offering "AC1900" speeds, I'd be a little
        disappointed if 100Mb/s were the best that you could get.
  • michaelkenward's avatar
    michaelkenward
    The lights on LAN (Ethernet) ports have nothing to do with the speed of the Internet. They tell you how fast things are moving on your local network.
    The LAN ports on most recent PCs are gigabit.
