annesarah
Feb 09, 2023Tutor
Why does netgear C6300 router not showing update firmware option?
There are several reasons why the update firmware option is not showing up on your netgear c6300 router. Common causes are:- Outdated Firmware: If router's firmware is already up to date, the optio...
johndevid
Feb 09, 2023Tutor
Thank you so much for sharing this amazing and informative blog post. Your attention to detail and thorough explanation has truly provided valuable insights and knowledge. I appreciate the time and effort you put into creating this content and helping others. Keep up the great work! #amaradevid
Kitsap
Feb 09, 2023Master
The C6300 is a combination cable modem Wi-FI router. Updating the firmware on the C6300 is accomplished by the internet service provider and not by the end user.
Additional information can be found here:
- michaelkenwardFeb 10, 2023Guru - Experienced User
Apart from that message, this whole thread seems to be no more than an attempt to set up a string of linkspam.
Reported.
Best ignored.
