stringhacker
Jun 23, 2018Tutor
Why is my smartconnect very stupid?
I chose the smart connect as recommended then set up 5 devices then I went to devices on the the Netgear nighthawk app and 4 of the five devices were connected to 5GHZ-2 and the one i especially wan...
- Jun 25, 2018
stringhacker wrote:
Is setting up manually as easy as changing the passwords and ssid’s
On the different bands?? Thanks again for replying and all the great info!!Yes, that is all you need to do on the router, then on the devices, pick the SSID you want it to connect to. You only really need to uncheck SMART CONNECT and change the SSID for 5Ghz-1 or 5Ghz-2 ones, no need to change both. Both can have the same password.
stringhacker
Jun 24, 2018Tutor
Michael, thank you for your reply, I was considering hardwiring, until my wife said they would find my headless body in a ditch!! Haha!
We paid quite a bit to have no wires,
(Everything in the walls) thanks again!
michaelkenward
Jun 24, 2018Guru - Experienced User
That's what Powerline is all about. No cables to upset the other half.
But first try to fix it with wifi.
