Girl1der
Jul 26, 2016Tutor
Why is there no DHCP Lease settings on a $200+ top tear router?
I need a Router with a DHCP Less time setting, I'm going to have to sell my R7000 or custom flash it becase a DHCP Lease time of 24hrs is a Very very short sighted setting. This setting causes 10's o...
- Retired_MemberAug 03, 2016
The wheels on the Bus go round and round.................
microchip8
Jul 26, 2016Master
Don't spend your time on this. NETGEAR's engineering virtually never listens and implements what people report or require. The only thing that will happen with your request is this:
1) it will get noticed by a community support member from NETGEAR
2) it will get passed on
3) Engineers will probably look at it and the chance is good they'll dismiss or forget about it
I've dealt with NETGEAR support and requests quite a few times myself and none of what I reported or requested got implemented. The only reasons why I'm using NETGEAR routers is that they a) have a decent build quality and b) they allow me to run third-party FW without too much effort. If one of the two wasn't met, I'll probably never consider NETGEAR again
Retired_Member
Jul 26, 2016address resevations wouldn't work?
- microchip8Jul 26, 2016Master
Retired_Member
still no excuse for not providing a basic networking feature. While it may be a work-around, I agree with the OP for not providing it
- VE6CGXJul 26, 2016Master
Issue could be not the lease time duration. Lease should be renewed periodically B4 running out(expiring). I think it is the job of firmware. Usually any where from 30mins B4 time expiry it should be continously renewed at set interval. If lease time is set shorter than renewal interval, that'll be a probem for sure.
- netwrksJul 26, 2016Master
Asus doesn't provide it either. Mostly 3rd party., Printers, Server's, networking devices (router's switches) should be set up with static IP's. Work stations DHCP. Network Management 101.
