Histrovian's avatar
Histrovian
Why my IP went from residential to business?
I have Charter Spectrum ISP and a Netgear nighthawk ac2400 router.
Im currently unable to login to a gaming server because according to them, my IP is identified as business.
However, When I dierectly connect my modem to my Pc and run a speed test or any sort of test to see if that’s the case, it says residential.
But when I connect from my modem to my router(netgear nighthawkac2400) and then to my pc and run the test again, it says business.
How do I configure it to residential? I live in a residential and confirmed with my ISP that it is indeed residential.
  • plemans's avatar
    What spectrum gateway do you have?
    Are you using armor, parental controls, or a vpn?
    have you tried changing the dns provider? Try googles at 8.8.8.8 or 8.8.4.4  or cloudfare's at 1.1.1.1
    What firmware is on the router?
    Are you playing on a xbox/ps4-5/what exactly is telling you this?
    • Histrovian's avatar
      Histrovian
      What’s spectrum gateway and how do I find it?
      Im not using any wall or vpn.
      Oh just an update, it seems like it is NOT the router that is giving me business classification. I plugged my pc directly to the modem this time and it says “spectrum business?”
      It didn’t the first time. I also called my isp and they said it was residential. Very puzzling!
      • michaelkenward's avatar
        michaelkenward
        Usually the modem box that connects you to the outside world.
        Your problem seems to be with Spectrum.
