FWIW's avatar
FWIW
Wi-Fi Authentication Error
Netgear Nighthawk X6 R8000
Firmware Version V1.0.4.46_10.1.63
Smart Connect Enabled
We have two Samsung S10s and both display the same problem.  They will be connected and working fine, then after a few weeks they start giving Authentication Errors.  They will connect, drop, reconnect, error out, etc.  If I reboot the router, they work fine for roughly 2 weeks, sometimes less..
Any suggestions to fix this?
  • FWIW's avatar
    FWIW
    Jan 21, 2020
    I don't know which circuit they were connected to, but haven't had a problem since I disabled the Smart Connect
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Do you know if this is only on the 5ghz network or both the 2.4 anf 5ghz?
    DarrenM
    • FWIW's avatar
      FWIW
