mattegem's avatar
mattegem
Wi-Fi not available
Both bands have disappeared, leds off on the router. Tried reset to factory settings, firmware updated but nothing. Internet is available I don’t know what else to do….
  • Kitsap's avatar
    Kitsap
    Jun 30, 2021
    You are welcome.  Please mark as resolved.
  • You have managed to manually turn off the Wi-Fi radios.  Neither firmware updates or reset to firmware default settings or cycling the power will change the state of the on/off switch.  Once turned off, it stays off until manually turned back on.
    When looking from the front of the router, the last two leds on the far right are a combination indicator/switch.  The second one in is the Wi-Fi radio on/off switch.  Press and hold for two seconds then release.  Your Wi-Fi radios should come back on.
    This information is in the manual.
    • mattegem's avatar
      mattegem
      I thought that were only leds not also buttons. I love you thanks mate! :D
      • Kitsap's avatar
        Kitsap
        Master
