sirsmedley's avatar
sirsmedley
Follower
Jan 20, 2022
WIFI and Ethernet simultaneously
I've had the R6700v2 Nighthawk AC1750 for a while and was wondering if you can have both WIFI and Ethernet working simultaneously. If so, how is it set up?
I moved my PC closer to where the internet comes into my house, and now can use a ethernet connection. Now nothing that runs on WIFI, like my printer and tablet, doesn't connect.
  • yea both wifi and ethernet work at the same time. Did you accidently turn off the wifi on your router? There's a wifi button on the right of your router that if you press it for 2 to 3 seconds it can be turned on/off.
1 Reply
