_chris
Apr 29, 2019Tutor
Wifi dropping connections constantly, I have tried everything
I cannot seem to solve this one. I'm just so frustrated that I'm ready to get a new router that isn't Netgear (maybe Ubiquiti/UniFi?). I have been very happy with this rotuer for years, but I just can't get a stable wifi connection since I moved to my new house. I know my way around networking so I've tried all the basics and I'm just out of ideas. Here are the things I've tried:
- Contact Netgear support. They suggested basic things such as changing the wifi channel, etc.. but after I replied doing all their suggestions they stopped responding to me and I have not had a reply back in about 3 weeks (I've followed up a few times). Not sure why they won't get backto me. I was trying to get it replaced via warranty, but I believe I have been abandoned.
- Factory reset the router and reconfigured
- Purchased a second router (same model) and migrated the settings via a backup
- Changing wifi channels, I used an app on my phone to scan nearby wifi signals to find a channel that had the least amount of networks
- I had the router plugged into a UPS (backup power) and thought maybe it was causing noise on the line, I've tried from the wall and from UPS
- Disabling all non-essential features
- Reinstalling latest firmware V1.0.9.64_10.2.64
- Disabled nearby devices that also had their own wifi networks (such as printers)
All of the above has resulted in the same problem. Seemly randomly (I can't go more then 24 hours) a bunch of devices start to disconnect from the Wifi. They either stay connected and have no network access or disconnect and are unable to re-connect. Occasionally those devices that are experiencing the problem will show up as "Wired" on the "Attached Devices" list. Once this happens the only option to resolve it is to reboot the router. I have no additional access points here, everything is wireless except for 2 devices which are my main machine and my home server. The wired connection never has any problems. When the wifi does work, my network speeds are very fast (I can peak around 400Mbps from the other side of the house). Devices showing the issue are anywhere from 2 feet away to 25ft away, distance doesn't seem to matter.
I don't know what to do and I am open to ideas. I have two R7000 routers here (one is brand new, one is 3 years old) doing the same thing. on the same firmware version. I have considered reverting the firmware, but I'm not sure which version to revert to.
It takes me about an hour to reconfigure the router every time I need to reset it. There are anywhere from 25 - 35 devices connected to the wifi at anytime. I've wasted probably 7-8 hours debugging this over the course of 2 months because it takes time to wait for the wifi to start to fail again. I've also noticed that both routers (over the course of 24 hours after a reboot) are making a slight buzzing sound that seems to get louder and louder up until the wifi fails.... not sure if related.
Maybe I just got two buggy units? Maybe it's the firmware? Maybe there's some kind of wifi interference there isn't another wifi signal?
Currently using 1.0.9.32 without issue for 72 hours now.
The .42 firmware has a bug with the VPN so I can't use that one since I use the VPN alot.
That's about the complete list why many experienced people here don't touch .64 firmware ... and operate older firmware instead.
