Tina-Mom's avatar
Tina-Mom
wifi off on my r7000
I just lost the wifi on my router. I am into the router settings and I see my wifi is turned off. I cant figure out how to turn it back on. I need help. Tina
  • > Yes, i clicked on the button and it takes me to the wifi setting page.
    > It dies not turn on.
       No, not a virtual button which can be "clicked on", an actual,
    physical button on the router.  The latest edition of the User Manual is
    almost useless, but you might look closely at the rightmost two
    LEDs/buttons on the top panel of the router.
  • > I just lost the wifi on my router. I am into the router settings and I
       You might get some ideas from a widely neglected resource:
          https://en.wikipedia.org/wiki/RTFM
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    LED descriptions and "Troubleshoot".  Pay particular attention to the
    "WiFi LED" (formerly known as the "WiFi On/Off button with LED", until
    some sub-genius "improved" the manual).  Did you press it?  Further
    reading might not hurt, either.
  • Yes, i clicked on the button and it takes me to the wifi setting page. It dies not turn on.
    • antinode's avatar
      antinode
      Guru
      • Tina-Mom's avatar
        Tina-Mom
        Thank you so much! That was it. I had no idea rhey were buttons. I did find a short sentrnce on page 100and something, but it never said were the button was. Thanks again!
