Jchannell
Jul 07, 2022Aspirant
WiFi only connecting to certain devices FIX
After 4 long years and about 10 WiFi routers later I finally figured out why my routers have all been trash. The reason? The name! All netgear routers use “netgear09” and so on…each name is different,...
Jul 07, 2022Guru - Experienced User
Um, since the beginning of WiFi time, router mfrs have setup factory SSID names as a default ONLY. These SSID names have never been meant to use fully for LONG term uses. Users have been and always recommended to CHANGE these factory names to something else. Been like this longer than 10 years.
SSID names can be ANYTHING.
- JchannellJul 07, 2022AspirantSuper user on a netgear blog huh? Lol
- FURRYe38Jul 07, 2022Guru - Experienced User
Just well experienced.
- michaelkenwardJul 08, 2022Guru - Experienced User
Spot on there. Although some older manuals do say:
"NETGEAR recommends that you do not change the preset WiFi SSID or password."
Jchannell might also like to know that they can change the default password from that on the router's label.
They can also change the password for the "admin" access to the router.
