Robert-sk-2017
Jul 30, 2017Follower
Wifi Router R6900 - disable WPS
Dear Community, I dont undestant about disable WPS functiuon. On support netgear is written that when I clear PIN code it means disable WPS, but on manuals is written that when is PIN clear, device a...
- Aug 03, 2017
Hi Robert-sk-2017,
Clearing or unchecking the Enable router's PIN will disable the WPS connection via the PIN but still WPS is working if you use the WPS button.
WPS via the button will only work if the device you are trying to connect uses a WPS button as well.
There is no option to fully disable the WPS.
JamesGL
Aug 03, 2017NETGEAR Employee Retired
Hi Robert-sk-2017,
JamesGL
Aug 06, 2017NETGEAR Employee Retired
Hi Robert-sk-2017,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
